Santana/Samurai Engine
Gardiner
Post by Gardiner » Sat Mar 02, 2013 10:55 am
I shall re phrase question as I was trying to do on phone.
Is there any issues swapping a 1986 413 Samurai engine into 1984 410 Santana
So far all I can see is the bracket for engine mounting in slightly different position is this correct.
Would it the matter of re-welding bracket on chassis off the Samurai ?
Any more hints tips etc would be appreciated.
mk1joe
Re: Santana/Samurai Engine
Post by mk1joe » Sat Mar 02, 2013 6:11 pm
should be a straight swap but are you going to use the 410 gearbox because i dont think the 413 lump will fit it.
Gardiner
Post by Gardiner » Sat Mar 02, 2013 8:07 pm
I think I will use the Samurai Ngine and Box complete
Post by Darrell » Sat Mar 02, 2013 9:04 pm
This may be helpful as what needs to be done to take the 5 speed box
(assuming your chassis has the 2 fork mountings at present)
I' sure there are other ways of doing it, but this good as it requires no chassis modifications :thumbup:
http://forum.suzukiclubuk.co.uk/vi ... 12/t,3855/
Post by Darrell » Sat Mar 02, 2013 9:19 pm
I don't know if it's possible to mount the flat plate further back across the 410 chassis forks and still use the original 5 speed mounting arm ??
Maybe need to be stepped to get the correct hight ???
Post by ScottieJ » Sat Mar 02, 2013 9:26 pm
The engine mounts will need modding to fit the 1.3, that guide is about just fitting a 5 speed 410 gearbox hybrid. It's a lot easier to fit it all if you have the later 410 with the newer gearbox mount.
either way I think it will be quite an easy conversion with only a small it of fabrication involved if you have everything out of a 1.3.
