free wheeling hubs info
dazerede
Post by dazerede » Mon Mar 04, 2013 4:19 pm
One of my freewheeling hubs is hard to turn going from free to lock
I heard its just strip them down and clean them
Is there a guide thing that I can use as I would proberly do it wrong
4” calmini lift kit :)
penpontgreenwoodwork
Re: free wheeling hubs info
Post by penpontgreenwoodwork » Sun Mar 10, 2013 10:14 pm
Hi All
One of the free wheeling hubs on my recently aquired 413 doesn't seem to want to be free. It turns to the free position easy enough but it won't spin and is still turning the prop. Any thoughts?
They don't make cars like they used to!
SJ 413, tin top.
Sammy front axle.
2"? lift Springs on front, shackles on rear.
On the road
Post by ScottieJ » Sun Mar 10, 2013 10:31 pm
Yes the section that slides in and out has probably become dissconected from the outer section, remove the 6 small 10mm bolts and remove it, re-assemble and refit, it's held on with a spring that sits in a groove in the splines.
http://forum.ih8mud.com/79-95-toyota-tr ... build.html
Post by penpontgreenwoodwork » Sun Mar 10, 2013 10:55 pm
Thanks for that. Can this be done without removing the hub from the vehicle?
SJ 413, tin top.
Sammy front axle.
On the road
Post by ScottieJ » Sun Mar 10, 2013 11:20 pm
If what I think has happened you'll just need to remove the front section to fix it. Just the 6 10mm bolts.
Then just start at this point in the write up i linked.
Post by penpontgreenwoodwork » Mon Mar 11, 2013 10:23 am
Done it! Thank you so much, invaluable knowledge. :rockin:
SJ 413, tin top.
Sammy front axle.
On the road
dazerede
Post by dazerede » Mon Mar 11, 2013 10:56 am
might try this at the weekend
as it is very hard to turn
