Clutch was slipping so pulled it all apart. Clutch plate is down to the rivets so thats obvious.
However, how much wear is ok on the flywheel. Should it be flat because if it should then mine is shot.
Its about 2mm deeper where the plate rides than the outside.
Do i need a new flywheel?
Flywheel wear???
Re: Flywheel wear???
It should be flat where the clutch friction plate touches. (clutch disc in diagram).
- e8fd3cd81304c3ff517ff1500ef431f4001f76ab.jpg (78.22 KiB) Viewed 2686 times
- clutch.png (353.18 KiB) Viewed 2686 times
Thanks for the second photo, mine is looking ok after seeing that.
