Starting
Starting
On the Sj413 with auto choke do u just get in and turn the key ? I did hear you press the throttle once then turn the key to start ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
The auto choke is activated with thermowax, so Im pretty sure you don't need to press the throttle.
Its not gonna hurt it though
Re: Starting
Cheers,starter sticking a bit guess this is probly due to being stood 6 yrs ,does a 410 one fit ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
No a 410 starter won't fit the flywheel is further away from the mounting face on an F series engine.
I tried to make one fit a while back and failed
Re: Starting
Dam,can they be refurbed ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
You can refurb them but not sure exactly how as I usually just chuck mitsi and bosch ones in the bin
Some spare parts for mitsi ones here (make sure you check the model number)
http://www.woodauto.com/Unit.aspx?Man=M ... f=M3T38981
and here
http://www.woodauto.com/Unit.aspx?Man=M ... f=M3T39981
Bear in mind though you can get a brand new one for £80
and here
Re: Starting
Can u where , I've seen some but they over a 100 quid
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
On those pages I liked to you, you can buy the whole starter or just the bits
Just be advised these are not really suitable for 1.6 conversions
Re: Starting
It's ok keeping engine and truck original ,thanks for the info
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
The couple I've looked at with sticky starters has been nothing more than rust in the solenoid. A strip down, fine emery paper and some WD40 sorted them.
