bearing retainers
Posted: Fri Mar 08, 2013 10:56 pm
by kiwizook
I stripped my rear axle, and painted it all, and when I started putting it together, I noticed that on one side the bearing retainers were a little bent
- side 1
- Pic_0309_118.jpg (364.35 KiB) Viewed 3927 times
- side 2
- Pic_0309_119.jpg (290.31 KiB) Viewed 3927 times
is this alright, or do I need to take it all apart and bend the retainer straight?
Re: bearing retainers
Posted: Sat Mar 09, 2013 10:59 am
by Darrell
Posted: Sat Mar 09, 2013 12:38 pm
Are the bolts done up tight in that pic? If not try cranking them up tight, might pull it in a bit and then you could just hammer the middle in. To be honest they are pretty flimsy anyway and should still hold the bearing in ok like that. Shame your in NZ Muddyzook sell heavyduty bearing retainers that are a good upgrade.
Posted: Sat Mar 09, 2013 10:18 pm
by dunnin21
Mine were bent all sorts of shapes just hammerd them straight, had no problems
Posted: Sun Mar 10, 2013 6:30 pm
by kiwizook
I undid bolts in tha picture, as soon as I saw they were as crooked as that. I will just tighten them up, and hammer them sort of straight, and she'll be fine
