Selecting and fitting a winch.
Posted: Sun Mar 17, 2013 9:44 pm
by HuwJones
Hi.
I'm looking to fit a winch on my 1989 SJ 410 Samurai. I have found this one on eBay.
http://www.ebay.co.uk/itm/251200249161? ... 1423.l2649
I think it should be more than enough for the SJ, according to the Haynes manual it weighs approximately 990kg, which is 2182lbs, so 4000lbs should be more than enough. I was planning on fitting another alternator to charge another battery which is only powers the winch.
My other question is, where/how would you mount the winch onto the front of a SJ? Would you bolt the winch onto a plate then bolt that using U-bolts to the round bar in the front?
I have never done anything like this before, so a description and photos will be much appreciated!
Huw
Re: Selecting and fitting a winch.
Posted: Sun Mar 17, 2013 10:19 pm
Too small. Need 6500lbs to 9000lbs, all dependa on if its for self recovery or recovering others, with potentially heavier (landrover) vehicles.
Based on a quick bit of military maths to recover a SJ at 1t up a 46* slope with damaged axles/tyres in very thick mud/clay/bog the pull required is 3.75t (8250lbs).
That is the extreme example and a safety factor has also been added into it to allow for safe working loads of strops, slings and shackles. You also need to remember that a winch advertised at 6000lbs for example only has 6000lbs pull when it has the minimum coils on the drum. If it has more than one layer of rope on the drum the pull is reduced.
That is an extreme example and a 9000lb winch would easily do for the most stuck self recovery situations. I would say 6500lbs would be more than sufficient as even in the worst case scenario a 2:1 pull can be used.
Posted: Sun Mar 17, 2013 10:30 pm
And if you were recovering the Blandrover out of the same bog up a 46* slope with damaged axle/tyres it'll be 5t pull (11000lbs) so our 6500lb winch could still do it on 2:1.
All of this is based on using the kit correctly and well within its limitiations and design.
I'm not gonna get into the H&S of recovery. My experience is basic to say the least. Thats just my recommendations.
I'm not sure of the quality but i have this earmarked
http://item.mobileweb.ebay.co.uk/viewit ... 1028362174
Also bear in mind mounting it correctly.
Posted: Mon Mar 18, 2013 9:31 pm
by HuwJones
Ah, i forgot to acount for the weight of sticky mud etc! And all of that maths.... not my department! Thanks for the advice. Sometime in the next months when i have enough cash i can get on with buying and fitting a winch to the SJ.
Huw Jones
Posted: Mon Mar 18, 2013 9:44 pm
Estimated pull is rolling resistance + gradient resistance + damage resistance + saftey factor
Rolling resistance is weight of vehicle divided by ground factor (can't remember the ground factors off the top of my head)
Gradient resistance is weight of vehicle x degree of slope divided by 60 (46* and over it is weight of vehicle)
Damage resistance is 1/3 weight of vehicle for one damaged axle, 2/3s for both axles
Safety factor is all the above divided by 4
All numbers are rounded up to the nearest ton.
As the SJ is so light the numbers get rounded up a long way. I'm going to opt for a 6000lb winch one day as on a single line pull it should be more than capable of recovering a stuck Suzuki.
Posted: Tue Mar 19, 2013 9:26 am
by ROBBIE
Before buying a winch check out how easy to get spares and the price of them. A lot of winches come from china and don't like to much use and being weathered ie stuck on the front of an SJ. I know this because I have a very heavy door stop for the shed
Posted: Tue Mar 19, 2013 9:29 am
The very heavy door stop. I use a transfer box at the moment. Mini gear boxes work very well too.
Posted: Tue Mar 19, 2013 9:33 am
by ROBBIE
Got to have something with a bit of weight them shed doors can slam quite hard
Posted: Tue Jul 15, 2014 11:14 am
by basil
Jordi wrote:The very heavy door stop. I use a transfer box at the moment. Mini gear boxes work very well too.
Maintenance free batteries are very good and loads about after 6 months use
basil
