I have just bought a full set of polybushes for my vitara, and am having trouble fitting one on the a wishbone. Do they have to be pressed or should they just slide straight on?
Cheers.
Vitara poly bushes
Re: Vitara poly bushes
Are they the bushes in 2 bits, IE : press in from both sides.
I would expect them to be a tight fit.
Two bits of plate and a threaded rod/bar are good for pulling them in.
Yes they are the bushes you push in from both sides. The treaeded bar idea sounds good so i'll give that a try. If not, i'll try a vice. Thanks for the advice.
