Alternator Please Help
Gardiner
Post by Gardiner » Sun Mar 24, 2013 10:25 pm
OK so here we go put a 413 engine into the 410 offroader and I have some wireing issues they are as follows.
413 Alternator rectangle plug
2 big White/Yellow Tracer Wires
1 Thinner White/Red Tracer Wire
Nothing on Spade Terminal with "B" On it this is how it was connected to engine.
410 Santana Wiring loom to alternator as follows
1 round ring connector connected to "B" on alternator going to loom/ battery.
3 Pin plug with :-
Black going to E
White/Green Tracer going to F
White/Black Tracer going to N
Question is any thoughts on how to connect 413 Alternator/Engine to 410 Loom????
Re: Alternator Please Help
Post by Darrell » Mon Mar 25, 2013 8:17 pm
The early 410 alternator has an external voltage regulator.
The 413 alternator has a built in regulator.
So I would disconnect the voltage regulator.
Connect the large wire W/BL to either of the large spade connections (I believe they are joined ?).
Connect the small spade connection to the W/R wire from the old regulator (dash light)
I think that's it, but would like other peoples thoughts on this :poke:
The original 410 alternator only put out 35amps* and that type 413 only puts out 40amps* so cable size should be OK.
(*according to my information)
Anybody done this conversion that can confirm this :thumbup:
Post by ScottieJ » Mon Mar 25, 2013 8:48 pm
All the 410s I've messed around with have been the later ones without the external voltage regulator and are wired up like your second diagram Darrell :thumbup:
Basically just wire it up as you would a standard Sj 413 is wired up after disconnecting it. the colours before the voltage regulator are the same.
Post by Darrell » Mon Mar 25, 2013 8:53 pm
That alternator does not have a switched live, unlike the ones with the round plug. :er:
Post by ScottieJ » Mon Mar 25, 2013 9:07 pm
The black w/white tracer is the switched live isn't it?
I just noticed you don't have that on your diagram though? Doesn't the rectangle plug on the 413 have a black w/white tracer and a white w/red tracer? Then the two thick white and yellow ones should go to the B+ on the alternator? That's how my 1.6 is wired up and I'm pretty sure that's how my Lwb is wired up but will check.
Gardiner
Post by Gardiner » Mon Mar 25, 2013 9:26 pm
Switched Live ???
So are you saying there should be a white/black wire going to alternator ??
Also where is the Voltage Regulator ?
So I can find wire from regulator and extend down to alternator and ignor all other wires ???
Post by Darrell » Mon Mar 25, 2013 9:32 pm
I have found a pic of the rectangular connection type.
Shows the large W/Y wires and just a white/red for the dash light.
Alt connection.png (152.35 KiB) Viewed 6831 times
Post by Darrell » Mon Mar 25, 2013 9:41 pm
Regulator looks like this, but I don't know where it is :oops:
Gardiner
Post by Gardiner » Mon Mar 25, 2013 9:49 pm
OK what about the white/yellow tracer that goes to loom would I put that to B+ on alternator
Post by ScottieJ » Mon Mar 25, 2013 10:03 pm
:oops: I've been thinking of a different plug and not that one. Not even sure if any of the SJs I've worked on have bad that plug?
