Looking for Parts for 1.9D Pick Up....need links!!!
Posted: Wed Mar 27, 2013 4:36 pm
by magnus_azores
i have a great 2004 anus with the original 1.9D Renault F8Q 284 Motor.
i need to order parts and i have the Suzuki part numbers, but i cannot find anything other than the suzuki dealer to provide them at a MASSIVE cost.
anybody know where i can get engine parts for my little girl?
thanks in advance.
Re: Looking for Parts for 1.9D Pick Up....need links!!!
Posted: Wed Mar 27, 2013 6:55 pm
by Tramp
I'll be honest, most of the people on this forum are from the UK, and in the UK we never had the diesel engine option, we went from the leaf sprung, single point injected petrol samurai (to 1996) to the jimny (1996 onward) & we were never offered a diesel. I can only imagine your best bet is finding out what other cars use that same engine, have a look at a parts list to see if the parts you need are identical, then ordering through Renault or check your local motor factor and see if they stock the bits for a Renault.
Sorry I couldn't be more help!
Posted: Wed Mar 27, 2013 7:33 pm
by Edweird
You know the engine model, so you could use that to track down the parts for that engine from Renault perhaps.
Posted: Thu Mar 28, 2013 3:13 pm
by HelioF
Hi i also have a Suzuki Samurai 1.9d Pick up, i live in the Azores, Terceira Island. What parts are you looking for ?
Posted: Thu Mar 28, 2013 3:38 pm
by HelioF
Here is a site from Lisbon:
http://www.megastore4x4.pt/
Posted: Sat Mar 30, 2013 1:19 pm
by magnus_azores
HelioF wrote:Hi i also have a Suzuki Samurai 1.9d Pick up, i live in the Azores, Terceira Island. What parts are you looking for ?
Suzuki Part #'s
11401-84CT1
GASKET CYLINDER HEAD KIT
11141-84CT0
CYLINDER HEAD GASKET only
12761-84CT0
TIMING BELT
15167-84CT3
GASKET only for Thermostat
OR
Replacement Thermostat, whatever is cheaper.
Posted: Sat Mar 30, 2013 1:34 pm
by magnus_azores
Tramp wrote:I'll be honest, most of the people on this forum are from the UK, and in the UK we never had the diesel engine option, we went from the leaf sprung, single point injected petrol samurai (to 1996) to the jimny (1996 onward) & we were never offered a diesel. I can only imagine your best bet is finding out what other cars use that same engine, have a look at a parts list to see if the parts you need are identical, then ordering through Renault or check your local motor factor and see if they stock the bits for a Renault.
Bummer, i don't speak the native language so well, so i have to stick to english speaking forums....but they don't sell my car in those countries. i have found a ton of links in Eastern europe for this model.
No other cars use this particular engine. The F8Q is used on the clio, megane and kangoo, but not with the 284 suffix. so it is risky to order parts from other F8Q's as i have no way of knowing what small changes they made. suggestions???
Posted: Sat Mar 30, 2013 1:38 pm
by magnus_azores
Edweird wrote:You know the engine model, so you could use that to track down the parts for that engine from Renault perhaps.
they told me to contact Suzuki dealership. i can get parts from Suzuki, but at a very high price. i am hoping to find some aftermarket manufacturers, but that might not be possible.
Posted: Sun Mar 31, 2013 10:55 pm
by HelioF
I have replaced the same parts that you’re looking for, some were from Renault Clio 2 and some from Renault Kanguu 1.9. They are cheaper and easy to come by.
Take a very good look at the engine's head, one the side that has the longer hole, see if the wall is wide enough, if it is not you will have to fill it . Do not forget to replace all bolts.
Posted: Tue Apr 02, 2013 4:04 pm
by magnus_azores
HelioF wrote:I have replaced the same parts that you’re looking for, some were from Renault Clio 2 and some from Renault Kanguu 1.9. They are cheaper and easy to come by.
what year anus do you have?
it seems strange to me that the Head Gasket would break on a 2004 motor...but i am the third owner, so there is no way to know how my anus was treated prior to myself.
how about you? why did your break?
thanks for the info.
