Reverse lights not working, help??
lordyharmerz
Post by lordyharmerz » Wed Apr 22, 2009 5:12 pm
Just sorting all the gremlins ready for MOT and have found i have no reverse lights, Both bulbs show no reading through a multimeter, have traced the wires from the rear lights straight down the middle of the car and up above the gearbox, But no switch, i just cant find it, any1 knows the whereabouts of it on a 410 santana?
Re: Reverse lights not working, help??
Post by ScottieJ » Wed Apr 22, 2009 5:29 pm
if your looking at the sj through the engine bay, you should just about be able to see the switch on top of the gearbox a couple of inches back from the edge of the bellhousing, might be able to get too it through the hole the gearstick comes through too???
lordyharmerz
Post by lordyharmerz » Wed Apr 22, 2009 5:34 pm
Ta mate,
urbanzook
Post by urbanzook » Wed Apr 22, 2009 9:56 pm
did you earth it off the body/chassis or did you use the - off the bayonet,
as this wood identify a earthing problem,
if your looking at the sj through the engine bay, you should just about be able to see the switch on top of the gearbox a couple of inches back from the edge of the bellhousing to the right,
lordyharmerz
Post by lordyharmerz » Thu Apr 23, 2009 12:07 pm
Yeah found that easily, was looking on the underside before, it turned out to be a bad connection on 1 of the wires that comes up into the engine bay from that switch, behind the distrbuter, there was a plastic covered spade connector had caroded, just swapped it out and they worked a treat, Ive got 2 reverse lights (does that mean anything? ), have been having trouble with bad earths under the hood for front lights but drilled a new hole and re-did all.
Also fitted a new fog lamp which again didnt work, again it was an earth problem . Thankfully all is sorted accept my defender side lights are vastly brighter than my main beams. gona purchase some new bulbs to cure that i hope.
So very nearly done now im getting impatient :roll:
