Help
Help
Has any one done a vitara conversion on an sj and used the electronic ignition distributer? Swapped engine over changed distributer for my old one from 1300, can get to run but can't get timing right distributer end?????? Help please
Re: Help
Im guessing your as far as you can go on the dizzy ajustment but need a bit more turn?
I just cut a pease out moved dizzy where i needed it and liquied metaled it up works fine and has dun for 3 years now
