virtual lift questions
suzukisteve
Post by suzukisteve » Fri Apr 05, 2013 11:25 am
ok so in the summer (pause for laughter) I need to get the welding done on my arches. it just seems to me like while its bein done I may as well do a virtual lift.
whats the best way to go around this without c*cking it up?
was thinking of using an oil drum as its already curved and I could probably get all 4 arches outta one drum.
and opinions and advice would be greatly appreciated
steve
pickle power!
Re: virtual lift questions
Post by ScottieJ » Fri Apr 05, 2013 12:10 pm
poor SJ it looks so nice as it is :cry:
How thick is the steel on an oil drum and whats the diameter?
It's really easy to get the shape into plan flat sheet, I literally just bend it over a tyre :lol:
Dan's build has good pics of the whole process, was a lot better than my first virtual lift, and I'm not sure you want to go quite as extreme as my last one :lol:
http://forum.suzukiclubuk.co.uk/vi ... /start,30/
suzukisteve
Post by suzukisteve » Fri Apr 05, 2013 1:06 pm
ah scottie dont say that, took me a long time to decide if I was gonna do it or nor ans now im not so sure again!
what would you do? wanna bit of extra room for articulation
pickle power!
Post by Jordi » Fri Apr 05, 2013 2:49 pm
I just used sheet body panel steel. Used the curve of the arch i cut out to shape it. Tack welded as i went.
Post by ScottieJ » Fri Apr 05, 2013 3:21 pm
suzukisteve wrote:ah scottie dont say that, took me a long time to decide if I was gonna do it or nor ans now im not so sure again!
Well what size tyres do you want to run ideally?
suzukisteve
Post by suzukisteve » Fri Apr 05, 2013 4:36 pm
well at the mo im runing 215/85r15 and they rarely scrub. I had to do a bit of cutting to the bumper mounts when I put the spacers on.
im happy with that size as I managed (just) to keep up with you guys on sailsbury plain. my only worry is that now the wheels are further out they'll scrub on the outer arches.
i like the spacers as it feels just a lil more stable. what do u think the options are?
pickle power!
Post by dan_2k_uk » Fri Apr 05, 2013 4:53 pm
How bad are the arches. If you can save them and just used a little spring lift.
suzukisteve
Post by suzukisteve » Fri Apr 05, 2013 7:23 pm
ah sj's go they ain't all that bad really. they need doing but its my no means rotted out.
yeah maybe just a few inches up would be alright, just don't have very much dosh to spend on the ol girl as we're savin for a house
pickle power!
Post by Jordi » Fri Apr 05, 2013 7:41 pm
My virtual lift was ample for 31s. Took a chunck out of the bulkead too. With my lift springs it'll be ample for 33s. :D
