handbrake on 410 it was a seized cable
dazerede
Post by dazerede » Tue Apr 16, 2013 7:33 pm
Wright guys trying to adjust my handbrake
but when I adjust it with handbrake off I adjust it until the pads just bite the drum and then I put handbrake on it doesn't do nothing and stays the same
Also how the fuck do u undo this fucking bolt on the t-box
because it is :pissed: me off as I want to book it for a mot :bawling:
4” calmini lift kit :)
suzukisteve
Re: handbrake on 410
Post by suzukisteve » Tue Apr 16, 2013 7:38 pm
I was recently told there is a rubber bung at the back of the drum, remove it and you should be able to adjust it up with a screw driver
pickle power!
dazerede
Post by dazerede » Tue Apr 16, 2013 7:46 pm
I have been adjusting it using this hole but its still not working
Perhaps it need new pads I'm not sure all I want to do is undo the big 27mm nut so I can look in side but I can't undo it
Post by andyrew » Tue Apr 16, 2013 7:50 pm
Easyer to undo. On the car. But now its off id use some wd40 and a big breaker
Bar. Maybe a little heat.
Post by ROBBIE » Tue Apr 16, 2013 7:54 pm
Is the cable ok? A couple of mots back mine wouldn't work even after adjustment, so got new shoes striped it shoes were still good turned out cable had seized. The nut , I wedged a bar between two of the bolts turned until bar hit chassis and undone big nut
dazerede
Post by dazerede » Tue Apr 16, 2013 7:57 pm
It's still on the car this is my spare 410 t-box :) as it shows a better pic of it
Going to let my dad have a go at it to see if he can work it out
chrisj410
Post by chrisj410 » Tue Apr 16, 2013 8:03 pm
I got my impact driver on it mate
dazerede
Post by dazerede » Tue Apr 16, 2013 8:07 pm
Havnent tried the cable yet
how can I do this ?
:D I tried undoing the nut this way but nothing happened except I hurt my hand :cry:
Just put some wd 40 on the nut
I don't have a impact driver tempted to drive it 2 miles and borrow my bosses workshop as he has all sorts of tools plus a 2 post car ramp
dazerede
Post by dazerede » Tue Apr 16, 2013 8:09 pm
kiwizook
Post by kiwizook » Tue Apr 16, 2013 8:20 pm
there is a little notch in the shaft the nut screws onto, and the nut has a little ding punched in it to prevent it from coming loose when in action. you will have to bend this back to be able to undo the nut, the easiest is to get a flat screwdriver that fits nicely in the groove on the shaft, and wack it in with a hammer to straighten the ding in the nut, hope this helps, else I will take a pic after work of my t box on the bench to show you
