wheel studs needed brand new
- dazerede
Can anybody help me as I am wanting 18 new I mean new wheel stud bolts
Plus 8 washers and bolts to hold the drum onto the shafts
As the studs that hold the drum on is the same size as the ones that hold the wheel on
I have around hand ones but I want new ones as some are crossthreaded and a bit damaged
- IMAG0300.jpg (1.01 MiB) Viewed 5267 times
4” calmini lift kit
4” calmini lift kit
- dazerede
Re: wheel studs needed brand new
Also I need a new wheel spacer stud it is a 30mm wheel spacer looks like this
- IMAG0305.jpg (874.56 KiB) Viewed 5265 times
- IMAG0306.jpg (962.32 KiB) Viewed 5265 times
- IMAG0307.jpg (834.51 KiB) Viewed 5265 times
4” calmini lift kit
4” calmini lift kit
- dazerede
Also I need a couple of these that hold the copper pipe into the cylinder I need them new aswell
- IMAG0301.jpg (950.54 KiB) Viewed 5262 times
- IMAG0303.jpg (776.86 KiB) Viewed 5262 times
4” calmini lift kit
4” calmini lift kit
- Ladaman
- Suzuki Guru
The brake pipe nut is an easy one.
If you go to a motor spares shop they will be able to make you a new brake pipe with the correct nuts. Just remember to take the nut, an old bit of pipe to show them the type of flare needed, and the length.
I cant help with the stripped studs, but someone else will I'm sure.
I assume you mean washers and nuts
http://muddyzook.co.uk/store/index.php? ... duct_id=10
- SJ studs.jpg (136.32 KiB) Viewed 5235 times
- dazerede
Ye i seen them washers and nuts but im a after the bolts aswell
Ye going to POP up to motor parts direct on tuesday to sort out the cylinder thing
4” calmini lift kit
4” calmini lift kit
This is the only site in the UK I can find selling any. http://www.walldonwaypartsshop.co.uk/pr ... 9119-12003 They only have 6, you may end up going to a main stealer for them
- dazerede
Yep that's the ones darrell but I need 15 but they only have 6 in stock
Mmm must call Suzuki sanfords then
Chears darrell
Chears darrell
4” calmini lift kit
4” calmini lift kit
- dazerede
Right I have sorted out my wheel spacer problems I emailed a few people who sell spacers and they told me to buy this ok they are a bit longer and wrong colour but its all good
Click Here for Ebay Listing
1/3 problems sorted
1/3 problems sorted
4” calmini lift kit
4” calmini lift kit
