any body got this thing
Posted: Tue Apr 30, 2013 8:10 pm
by dazerede
Has anybody got a set of these things not sure what they are called as I am missing a drivers side one but I would like to have both
Re: any body got this thing
Posted: Tue Apr 30, 2013 8:43 pm
by andyrew
If its fitted on a sami im gueessing ill have them
Posted: Tue Apr 30, 2013 9:08 pm
by dazerede
OK CHEARS is it just 1 back plate or 2 u are sending out Chears
by ROBBIE
In your other post I said I was missing a part that is it
Posted: Tue Apr 30, 2013 9:09 pm
by dazerede
Oh I see I was on about do I need the long bar adjuster
Umm if andrew doesn't have a set I might try it without
Posted: Tue Apr 30, 2013 10:15 pm
by andyrew
Hey dude
I have two complete rear brake setups so can send you out any bits you need .
I run jap so Spanish bits are not much use to me :doublethumbs:
Ill give the back plates a quick blast in the sand blaster for you too.
Posted: Tue Apr 30, 2013 10:20 pm
by dazerede
Lovely Chears chap that would be lovely if I can get 2 backplates and also do u have 2 of them thing this here
Posted: Tue Apr 30, 2013 10:33 pm
by andyrew
Pretty certain that they are fitted. I tried to get a picture earlier but me battery was flat.
Doh!
Posted: Wed May 01, 2013 8:00 am
by dunnin21
There for the auto ajust would thing thay need to be there
Posted: Wed May 01, 2013 4:11 pm
by Darrell
The mechanism is there to adjust the handbrake and the footbrake. Although looking at it I would say it's operated when the handbrake is used. As you have no handbrake cable to it, it won't work. I would fit it but I think you may over time have to take the drum off and adjust it manually.
