how to take the shafts out
dazerede
Post by dazerede » Wed May 01, 2013 6:06 pm
Just a quick question on the axles I have got to take 1 of my backplates of on my rear axle I have undone the 4 bolts holding it on the casing how do I take out the shaft does it pull out or do I need to take the diff out
I looked in the haynes manual and it says it should pull out but I tried that gently as I don't want to buy any more stuff
4” calmini lift kit :)
Re: how to take the shafts out
Post by ROBBIE » Wed May 01, 2013 6:20 pm
Need a slide hammer or if its the knackered back plate hit it with a hammer
Post by turbo-tom » Wed May 01, 2013 6:30 pm
As Robbie says you need a slide hammer and some balls mate ;)
dazerede
Post by dazerede » Wed May 01, 2013 6:38 pm
Oh ok I just didn't want to hit it too hard incase I damage something
Chears guys
And also Chears for fast response that's why I love scuk :doublethumbs:
Post by Jordi » Wed May 01, 2013 6:40 pm
Late as usual. Slide hammer is easiest. Or bray shit out of the back plate with a BFH. When it comes out watch for the oil seal and any oil dribbling out.
gp7186
Post by gp7186 » Wed May 01, 2013 6:44 pm
I normally reverse the brake drum and bolt it back on then hit it with a hammer using a nice piece of wood to protect the drum always hit around the centre and from side to side
Gaz
dunnin21
Post by dunnin21 » Wed May 01, 2013 9:43 pm
I use same method as Gaz as I dnt have a slide hammer
Post by Jordi » Wed May 01, 2013 9:54 pm
I bought a slide hammer. Made the job so much easier.
Hopefully i won't have this issue much longer. Once RW has his full float sorted. Saving for that one next. If i sell my 31s that should almost cover it.
kibris
Post by kibris » Thu May 02, 2013 7:58 am
I used my hi lift jack makes a crackin slidehammer - bolt the base to the drum and wack away! job done :salute:
