All at Sea
The Zee
All at Sea
Post by The Zee » Tue May 14, 2013 12:08 pm
On the members map I seem to be 10 miles out in the North Sea, off the Norfolk coast when in fact I am in Sussex. I know the Jimny is good off road, but come on! :S
Re: All at Sea
Post by ScottieJ » Tue May 14, 2013 12:13 pm
That any better :thumbup: you need to drag it to where you are when first set up, the map doesn't use your profile location ;)
Rhinoman
Re: All at Sea
Post by Rhinoman » Tue May 14, 2013 1:19 pm
ScottieJ wrote:That any better :thumbup: you need to drag it to where you are when first set up
How do you do that? when I try to drag it it pulls the whole map across.
Re: All at Sea
Post by ScottieJ » Tue May 14, 2013 1:22 pm
might still be issues with the map to be honest, It was designed to work with an older version of PHPBB and I think the developers gave up on it so it doesn't work as well as it used to, I'll move you ;)
Re: All at Sea
Post by twiss » Tue May 14, 2013 1:24 pm
When you are in the user control panel and go to set the location, the map will always start with your marker bang in the middle. If you hover your mouse pointer over it, it will change from an arrow to a hand.
This means you are over the marker, then pick up and move.
As Scottie says, its an old map. I've been trying to get it working properly again for a while but its not playing ball!
Re: All at Sea
Post by ScottieJ » Tue May 14, 2013 1:28 pm
everytime I go to search for the location it just throws me back out onto the forum, Only way I seem to be able to move markers in in the ACP
Re: All at Sea
Post by twiss » Tue May 14, 2013 1:51 pm
Hmmm yes the search doesnt work! I will have a fiddle around with it when I get home!
The Zee
Re: All at Sea
Post by The Zee » Tue May 14, 2013 2:09 pm
ScottieJ wrote:might still be issues with the map to be honest, It was designed to work with an older version of PHPBB and I think the developers gave up on it so it doesn't work as well as it used to, I'll move you ;)
Cool !
I'm in Sussex now, thanks
Re: All at Sea
Post by twiss » Tue May 14, 2013 2:17 pm
The Zee wrote:Cool !
The best place to be ;)
The Zee
Re: All at Sea
Post by The Zee » Tue May 14, 2013 2:33 pm
I am often in Shoreham on the beach with my dog.
