Page 1 of 2
sj410 in water
Posted: Sat May 18, 2013 11:47 pm
by ants1992
hey was just wondering how do you lot all go in water wen running the petrol engine
Re: sj410 in water
Posted: Sat May 18, 2013 11:50 pm
by dan_2k_uk
Just drive in! ;)
Re: sj410 in water
Posted: Sat May 18, 2013 11:53 pm
by turbo-tom
decent water proof snorkel go in be brave drive out the other side job done ;)
Re: sj410 in water
Posted: Sat May 18, 2013 11:58 pm
Depends how deep it is.
If its real deep snorkel and water proof the electrics. Anything upto a couple of foot just go for it.
Re: sj410 in water
Posted: Sun May 19, 2013 12:03 am
by dan_2k_uk
A SJ has electrics?!?!
Re: sj410 in water
Posted: Sun May 19, 2013 12:05 am
dan_2k_uk wrote:A SJ has electrics?!?!
Mine has loads. Quite a few are a bit dodgy.
Re: sj410 in water
Posted: Sun May 19, 2013 12:08 am
by dan_2k_uk
Mine will run underwater 95% of the time
Scotties is a little more temperamental :D
Re: sj410 in water
Posted: Sun May 19, 2013 12:17 am
I've never had an issues in water yet. I'd like to get my snorkel on at some point though.
Electrics will dry out. A liberal coating of WD40 or similar seems to help too.
Biggest issue i always had on the SJ was the headlamps filling up if you staying in the water too long.
Re: sj410 in water
Posted: Sun May 19, 2013 9:02 am
by ROBBIE
Jordi wrote: Biggest issue i always had on the SJ was the headlamps filling up if you staying in the water too long.
Yep they need a small hole int the back to let it out
Re: sj410 in water
Posted: Mon May 20, 2013 9:45 am
Ive never had a problem with cutting out underwater, the last bit of fording I did came up to the tops of the wings and ended up OK!
Cheap thing to do that could save you, seal the distributor cap with a rubber/latex glove and some cable ties! The dizzy is by far the most susceptible part to water IMHO
Everything else will get wet, stop working, then dry out, dizzy gets soaked and ur stopped haha
