Fitting Samurai Axles to SJ
NylonAdmiral
Post by NylonAdmiral » Tue May 21, 2013 9:41 pm
I picked up some Samurai axles the other day to fit to my SJ.
I've started stripping them for a rebuild and also read this thread about moving the perches:
http://forum.suzukiclubuk.co.uk/vi ... =12&t=2801
I've got a couple of questions I was hoping someone might be able to help with:
1. I'm looking at moving the perches inwards and I'm figuring the inboard side of the perch is going to require quite a lot of cutting away in order to fit it because the cross section of the axle gets notably wider. Anyone done this and got any pointers (or maybe some pictures?) or do I just get the angle grinder out and get creative! :)
2. I started stripping the axle and was expecting to find a normal spindle nut. Instead I found the crazy looking nut shown in the picture below. Anyone know where I can get a tool to undo this thing?
3. I was looking at these perches:
http://www.mountaingoatperformance.eu/s ... 3-410.html
They offer the option to be able to reposition the axles forward or backwards slightly, is there any advantage to this?
4. I have a bit of play in the rear diff. If I hold the flange that bolts to the rear prop and shake it about there is some play. I just read this post:
http://forum.suzukiclubuk.co.uk/vi ... =12&t=5812
In which Scott mentions that rebuilding the diff may not be a particularly fun job. I've found one on ebay for £25. Has anyone rebuilt a rear diff, and if so would you do it again or would you just cheat and pay £25 for another one?
I think that's it... any suggestions appreciated!
Thanks
Hub nut.jpg (221.62 KiB) Viewed 6647 times
dazerede
Re: Fitting Samurai Axles to SJ
Post by dazerede » Tue May 21, 2013 9:44 pm
scottiej has put samurai axles on his 410
4” calmini lift kit :)
NylonAdmiral
Post by NylonAdmiral » Tue May 21, 2013 9:47 pm
Thanks Dazerade, that's handy as he actually lives pretty close to me... I wonder if he has the tool needed to undo that spindle nut...
Post by dan_2k_uk » Tue May 21, 2013 9:58 pm
Thats part of the FWH.
Remove the circlip from the end of the shaft and undo the bolts holding it to the hub and it will slide off to reveal what you were expecting to see.
ferris
Post by ferris » Tue May 21, 2013 9:59 pm
Its not a nut, there is a c-clip on the end, take that off and the hub will slide off the shaft.
Dan beat me to it :lol: .
NylonAdmiral
Post by NylonAdmiral » Tue May 21, 2013 10:04 pm
dan_2k_uk wrote:Thats part of the FWH.
Hmmm... I just ran outside and checked. Now that you say that it does seems obvious :oops:
I'm going to blame the poor light on the fact that I didn't see the circlip :D
NylonAdmiral
Post by NylonAdmiral » Tue May 21, 2013 10:08 pm
Thanks Ferris :)
Anyone got any thoughts on whether to tackle this rear diff or just swap it out?
Post by dan_2k_uk » Tue May 21, 2013 10:11 pm
I'm going to build up some vit r&p's I've got into some trashed sammy diffs when I lay my hands on the trashed diffs. Until then I cant tell you.
Don't wanna waste my good ones on a conversion.
NylonAdmiral
Post by NylonAdmiral » Tue May 21, 2013 10:17 pm
Thanks, well I'm leaning towards just swapping it out for now. The parts I'd need to do the job actually appear to be more expensive than the diff that's on ebay! :shock:
Post by ScottieJ » Tue May 21, 2013 10:18 pm
I have all the gear to set up diffs :thumbup: would be best to get a set of pinion bearings, a new seal and a new crush collar.
As for the diff side perch, just grind it out until the perch sits flat, I've got a very basic jig that I use to set the perch positions if you want to borrow it?
