Gearbox bearing re build kits
ojr1979
Post by ojr1979 » Wed May 22, 2013 10:21 am
Hi looking to do a rebuild on my sj410 5 speed gearbox and I've noticed that the bearing on the front end ntn 63/28 lu is a sealed bearing,it's the only one that's a sealed type from what I've seen so far.however all the rebuild kits I've seen don't sell a sealed bearing there all open like the rest of the bearings in the case so my question is does this even matter??? Cheers
Pugsley
Re: Gearbox bearing re build kits
Post by Pugsley » Wed May 22, 2013 8:08 pm
I've not actually rebuilt a 5 speed unit but a few months ago I did so on my 4 speed sj410 (now sold) - yes the bearing you describe was the sealed type, possibly exactly the same specification you described. I think it is important to replace it with correct type because the plastic cover on the bearing seals the oil - use an uncovered bearing and it would flow through the bearing freely.
I'm sure that you will have no trouble getting this bearing - I got mine off the shelf in Barnstaple at a very reasonable price and you are better located than myself in the depths of the Westcountry.
ojr1979
Post by ojr1979 » Wed May 22, 2013 8:54 pm
Ok pugsley thanks for the advice,if I wanted to replace just that bearing any ideas where I might get one from?
NylonAdmiral
Post by NylonAdmiral » Wed May 22, 2013 8:58 pm
Although I haven't tried sourcing the particular bearing you're referring to, I have been amazed at the parts that I've been able to get off the shelf or over night from my local Suzuki dealership. Some are really well priced, others are ridiculous but I've found it's always worth a go.
ojr1979
Post by ojr1979 » Thu May 23, 2013 3:11 pm
Just tried ringing suzuki and they quoted me £47 just for that bearing! No way am I paying that!
Post by ScottieJ » Thu May 23, 2013 3:17 pm
What rebuild kits are you looking at?
ojr1979
Post by ojr1979 » Thu May 23, 2013 5:33 pm
The google results all seem to be from America?
ojr1979
Post by ojr1979 » Thu May 23, 2013 10:27 pm
Had someone who works with bearings day in day out take a look and said the bearing is fine I now believe it to be the needle bearing directly behind! Anyone got a part number for this? Thanks
Post by Darrell » Thu May 23, 2013 11:21 pm
I would measure it as well, but all the info I can find says --------->
ojr1979
Post by ojr1979 » Thu May 23, 2013 11:33 pm
Thats brilliant thanks darrell!
