seals and gaskets
Posted: Wed May 22, 2013 3:12 pm
by windsor
where is the best place to get seals and gaskets from i have allready got new axel seals but want new oil pan gasket and stearing nuckle seals as mine are starting to seap
Re: seals and gaskets
Posted: Wed May 22, 2013 3:34 pm
by dan_2k_uk
I got knuckle seals from suzuki. Remember they are to keep crap out not keep oil in. They should leave a bit of grease behind as they movr but if they are properly leaking it is oil from the axle and its actually the internal axle seal on the shaft that needs replacing.
Originally they werent fitted with a sump gasket and suzuki used sealant. I have a aftermarket gasket on mine though. Think it was an ebay job.
Posted: Wed May 22, 2013 3:38 pm
by windsor
cheers i have a load of liquid gasket from bike bilding so that should do the job and looks like i have anuva axle seal to replace then nevermid i expected it when buying a 19year old truk lol
Posted: Wed May 22, 2013 6:52 pm
by turbo-tom
I found that my local dealer can still get little parts etc but things like axle seals etc was ebay
