The little bolt bit that stops the gear lever spinning round
You all know the one. It bolts in from the back of the box.
Where can i get a one? There was a mod on here somwhere to sort it but i can't find it.
Re: The little bolt bit that stops the gear lever spinning r
i just got a normal bolt and ran the end in a bench grinder until it fit in the gap, works great. no slop at all
I did the same as Ricky but used an angle grinder and a drill.
- ianedwards
- SCUK Addict
id recomend using a bolt, and doing as the guys say.
i bought a kit from mountain goat performance, came with a new bolt, and replacment bushes for the gear stick and transfer box,
im going there on way home, do you want me to get the bolt out and get the dimensions for you to copy.
Ian
Ian
Ian.
Ian.
That would be brill bud.
May even buy that kit and do the lot.
If they are correct it means i managed to find part numbers all by myself. Gonna give Suzuki a ring later on. Don't think they're open at 04:50.
01935-08006 Bolt
08321-21083 Spring Washer
01935-08006 Bolt
My suzuki dealer didn't recognise those part numbers but have ordered me the correct parts off this diagram. About £3 i think he said.
- ianedwards
- SCUK Addict
Sorry, I got called back into work on the way home yesterday. I didn't have a chance to go up there but it sounds like you have sorted it out.
Ian
Ian
Ian.
Ian.
All sorted cheers. Will be at my local Suzuki dealer tomorrow.
