Will a 1.3 rocker cover fit a 1.6?
My 1.6 rocker cover is a bit manky. Will a 1.3 cover fit straight on?
- turbo-tom
Re: Will a 1.3 rocker cover fit a 1.6?
my guess is you might be able to because you can put the 1.6 head on a 1.3 block etc but i guess that means nothing! try it its only 4 bolts!
- Edweird
I can't see Suzuki making more than one Rocker cover design for the SOHC 4-cyl G-family engine. Saves on moulds
They are different shapes.
I don't wanna peel the 1.6 cover off before i know as i haven't got a spare rocker cover gasket.
If i know it'll fit i'll get a gasket and then swap them. If it won't fit i'll just wire brush it down and try the VHT paint again as i like to waste money.
Cheers Scottie. I'll get a rocker gasket and give it a go.
- mike harris
- SCUK is my life
yeh will be fine !!
rtv it !!
rtv it !!
