Anybody running a RS full float?
Just wonderin is anyone is running the RS kit.
Any good?
Any good?
Re: Anybody running a RS full float?
Mike and Silverzuk are, I've got one that was abused for a few years by Tim pink on his racer and the shafts look fine.
Mine is going on as soon as possible.
Know if anyone has had oil leak issues?
I heard theres no oil seal on them?
silicone the drive flange and cap and there should be no issues. That's all that you do on a land rover axle.
- kibris
Has Rockwatt got his sorted yet? - I am in th process of collecting all the bits required to do this mod.
In a word, no.kibris wrote:Has Rockwatt got his sorted yet? - I am in th process of collecting all the bits required to do this mod.
Not sure on the silicone. Once the oil gets as far as the bearing it'll wash the grease out, won't it?
I presume regular stripping and greasing would be advised?
Thats a shame RW hasn't got his going was gonna order mine this week
Well regular stripping and greasing is needed anyway when you offroad water always finds its way in
I may have to bite the bullet and order one soon.
Not sure what RWs plans are. Probably wait till i destroy the current bearings.
To be honest It wouldn't be hard to add an oil seal, all you need to do is machine up a holder that goes in where the old bearing would like so, I'm pretty sure there is a good surface for a seal to run on the RS shafts there.
