Power steering, Year 2000 Grand Vitara 1600cc
apwbee
Post by apwbee » Thu Jun 20, 2013 8:02 pm
I went to get some lunch this afternoon, all of a sudden steering went very hard. Pulled over and red liquid all over the floor, further investigation i have now discovered the metal hose that runs under the radiator has ruptured and leaked all my power steering fluid out. Replacement is going to take a couple of weeks from Japan, i cannot live without my car for that long. Seen a few sites saying cut the belt and save the pump, but then the battery wont charge? Is it worth it in the short term? Can the pipe be repaired? replaced with some form of rubber hose? welded? Need help before the morning as i have to go to work???
Adrian
Ruptured pipe.jpg (1.17 MiB) Viewed 3583 times
Re: Power steering, Year 2000 Grand Vitara 1600cc
Post by Jordi » Thu Jun 20, 2013 9:57 pm
If you remove the belt the battery should still charge.
To the best of my knowledge (and looking at your photo) that belt only drives the PAS pump. The other belt drive the alternator and water pump.
vitara_mad
Post by vitara_mad » Sat Jun 22, 2013 6:57 pm
ive got some power steering pipes for a gv
