Fastback Soft top
- HuwJones
Fastback Soft top
I'm looking for a fastback soft top for my SJ. I went for a drive to pick up some take away and ended up with a soaked arse :/
I'm not too keen on the looks of the 'propper' square soft tops, i think the fast back looks cooler
So, does anyone know where i could get one?
Huw
Huw
There's three ways of doing things,
1) The Right Way,
2) The Wrong Way
3) My Way.
2 & 3 are usually the same.
1) The Right Way,
2) The Wrong Way
3) My Way.
- turbo-tom
Re: Fastback Soft top
- HuwJones
Ouch!! Sheet steel is cheaper...
1) The Right Way,
2) The Wrong Way
3) My Way.
1) The Right Way,
2) The Wrong Way
3) My Way.
- turbo-tom
Yep alot cheaper! , mine came when i bought my truck, they come up on ebay from time to time!
Ad make a steel one with a frame and put some boot hydros onit and looks so the sloped bit opens like a boot
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
cd players
99% rust free
alloys
bukets
- littlesammy
huw i have a water tight one but i hate it.,id prefer a hard top so i can get seats in the back.
Help me find a hard top and ill do a deal on my fast back.
Liam.
Liam.
87 Samurai with added spice !
- HuwJones
Sounds like a plan!littlesammy wrote: Help me find a hard top and ill do a deal on my fast back.
Liam.
1) The Right Way,
2) The Wrong Way
3) My Way.
1) The Right Way,
2) The Wrong Way
3) My Way.
- littlesammy
HuwJones wrote:Sounds like a plan!littlesammy wrote: Help me find a hard top and ill do a deal on my fast back.
Liam.
And ive got mates that live near Ryhll!
- HuwJones
I was chatting with a few guys at work today and them recon I should just change the body. How difficult is it to swap them over? From having a look underneath and under the bonnet, I don't think it would be that difficult.
On another note.... does anyone have a tin top shell in reasonable condition in the 'spares box’?? I'd prefer to buy just the shell, as I won't be able to afford the entire car + no space for it.
I'm still keeping an eye out for a hard top Liam.
Thanks
Huw
Thanks
Huw
1) The Right Way,
2) The Wrong Way
3) My Way.
1) The Right Way,
2) The Wrong Way
3) My Way.
Its just six body mount bolts i think, undo the front clip, steering column, pedals, brake pipes, remove gear levers, undo all wires clipped to it. Unbolt everything from the bulkead.
Depends if you can get a body from the same series 410/413/samurai. May require dash / dials changing.
Hardest part will be finding a body worth putting on.
