what do you think to this electronic ignition?
Posted: Fri Jul 26, 2013 5:12 pm
by Jay18
Re: what do you think to this electronic ignition?
Posted: Fri Jul 26, 2013 6:03 pm
by dan_2k_uk
Thought you already had one?
Posted: Fri Jul 26, 2013 6:20 pm
by Jay18
yep I've got a cheap universal one but this one seems better, it replaces the points and comes with a new coil, so it Gould give an even better spark then shouldn't it?
Posted: Fri Jul 26, 2013 10:52 pm
by Rhinoman
Use a 413 dizzy, its a similar setup
Posted: Fri Jul 26, 2013 10:56 pm
by Jay18
dont really want to go into buying things like that just want to keep it simple really, this is suppose to give a better spart at the plugs so that the fuel burns better and will hopefully gain my more mpg..
Posted: Fri Jul 26, 2013 11:00 pm
by Rhinoman
Compared to a bad set of points it may do but the Lucas Sports coil, while it was great in 1950, isn't up to much these days.
Posted: Fri Jul 26, 2013 11:18 pm
by Jay18
hmm, i have a gamatronix black top electronic ignition, just needs to be wired up, not sure how to do it yet so might try that tomorrow when ive fitted the new carb..
Posted: Fri Jul 26, 2013 11:51 pm
by Darrell
Posted: Sat Jul 27, 2013 8:24 am
by Jay18
yep I have haha, I think I'll fit the one in got and see it if makes any difference..
I will use your amazing diagram
Posted: Sat Jul 27, 2013 10:03 am
by Rhinoman
That type usually works reasonably well on an old style engine like the 410, you just need to make sure that the heel od the points is well greased to stop the gap closing up. I used a few of that sort years ago and I did notice that the engine would run a bit smoother but I never noticed any improvement in economy, we used to combine then with a high output coil like a Bosch Blue Coil but the extra current and voltage did reduce the life of the transistors.
