1.6 mpfi conversion, what is needed?
Jay18
Post by Jay18 » Thu Aug 08, 2013 10:24 pm
other than the bits needed to do a normal 8v conversion like a 413 box, flywheel, starter etc..
what else is needed?
I know I would need a sammy fuel tank with fuel pump built in..
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Re: 1.6 mpfi conversion, what is needed?
Post by dan_2k_uk » Thu Aug 08, 2013 11:05 pm
Loom and ecu.
Post by turbo-tom » Thu Aug 08, 2013 11:07 pm
engine mounts.
Jay18
Post by Jay18 » Thu Aug 08, 2013 11:57 pm
I know about the engine mounts, have to move them when ya do a 1.6 8v conversion aswel, so it's just electrics then?
the block the same as a 8v?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
gp7186
Post by gp7186 » Fri Aug 09, 2013 1:13 am
Yeah as already been said loom and ecu to start. If you get a vitara fuel tank there is a tapped ring which the fuel pump mounts this can be swapped over to the sj tank you will see there is a pressing on the sj tank just drill a 70mm ish hole in the centre of it and weld down the ring and your sorted. Fuel lines will need to be replaced I re worked the donor vitara lines to fit my sj. Its much easier to get a donor vehicle then you can swap everything over and then sell the rest of the parts not needed. Some people fit the vss from the vitara clocks but I aint and it runs well. Heres a pic of mine when I just fitted it
Jay18
Post by Jay18 » Fri Aug 09, 2013 1:22 am
thanks mate, what rad have you got in yours? and how have you fitted it?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
gp7186
Post by gp7186 » Fri Aug 09, 2013 2:44 pm
The rad is a 42mm 2 core alloy 'racing' one from a honda civic they are very small and fit nicely with a few simple brackets and it only cost £70 new from ebay but you can get standard civis rads for half that new and they are designed to cool a 1800 vtec . I also used a cooling fan from an escort rs turbo as again they are very compact but powerful and very easy to mount heres some pics
Post by Edweird » Fri Aug 09, 2013 2:56 pm
Blue wires and hoses. It's a well known fact of science that those make a car go faster. As does red paint and flames.
gp7186
Post by gp7186 » Fri Aug 09, 2013 4:43 pm
Edweird wrote:Blue wires and hoses. It's a well known fact of science that those make a car go faster. As does red paint and flames.
Il have u know those blue rad hoses gave an extra 10bhp alone
windsor
Post by windsor » Fri Aug 09, 2013 9:05 pm
You for got wonky raceing stripes make your car quiker two
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
