Hi all
Could someone please confirm that the timing mark on the 410 is the right angled point on the flywheel housing. I can't see any lines marked on the housing so assume it must be the point of the triangle lines up with 10 degree btc.
also being a mechanical advance unit assume I should put a few drops of engine oil down holes in distributor onto springs every so often. Is this correct.
Thanks
Steve
SJ410 ignition timing marks
Re: SJ410 ignition timing marks
Yes that's correct with the marks
I've never really bothered with dribbling a bit of oil down onto the springs but doubt it would hurt
Thanks for the confirmation.
Timing was slightly out, now running like a sowing machine.
Steve
Steve
- turbo-tom
Ive never put a few drops of oil down it. But it wont hurt if you do!
