is the standard airbox restrictive
coupedriver
Post by coupedriver » Mon Aug 19, 2013 11:00 am
As the title says really,has anybody noticed performance gains with a k&n type or cone filter?just wanting opinions before I spend my hard earned,Thankyou
Re: is the standard airbox restrictive
Post by Jordi » Mon Aug 19, 2013 11:54 am
I don't belive any air filter makes a noticeable improvement on the SJ. I jntend to swap back to a standard air box as it was to add a snorkel to and also easy to waterproof.
Post by Edweird » Mon Aug 19, 2013 12:04 pm
The intake manifold is the main restriction on the intake side of the engine as far as I know.
Post by turbo-tom » Mon Aug 19, 2013 12:35 pm
Air filters make no difference to the engines so best to stick with the cheapest option aka standard! :lol:
Boyes
Post by Boyes » Mon Aug 19, 2013 1:19 pm
He's got a vit :) and I wouldn't bother tbh spend it on something useful a snorkel if you want to go wading or a cheap lift (rover & merc springs).
Post by ScottieJ » Mon Aug 19, 2013 1:24 pm
I would never use a K&N style air filter on an offroader. paper or foam only.
There's a reason they allow more airflow and that is because they don't actually filter out the finest dust, fine on a road car but not really what you want in an off roader that could be used in dusty environments.
I swapped to an aftermarket airfilter on my old vit and didn't notice any difference, in fact I swapped back to the original airbox after a short while.
coupedriver
Post by coupedriver » Mon Aug 19, 2013 4:03 pm
Standard with snorkel it is then,thanks guys.
I was reading about the rover and merc springs but couldn't find which ones to use or anybody that's actually done it,I've got till beginning of next month to decide(that's when she gets paid)between bigger springs or spring spacers
i_am_me
Post by i_am_me » Mon Aug 19, 2013 9:02 pm
grand vitara springs will fit aswell and will give you 1.5" lift.
if you go above 2" lift on the springs you may start encountering problems due to the vits design but im running 3" lift without too many issues.
If at First You Don’t Succeed Skydiving Is Not for You
Rhinoman
Post by Rhinoman » Mon Aug 19, 2013 10:28 pm
I'd like to test one properly but I don't know anyone that doesn't already run a snorkel.
windsor
Post by windsor » Tue Aug 20, 2013 7:21 am
I know there rover 200springs but cant remember witch merc springs
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
