Leaky Transfer Box
NylonAdmiral
Leaky Transfer Box
Post by NylonAdmiral » Mon Aug 19, 2013 11:08 am
I just found that my transfer box seems to be leaking a bit of oil but I can't seem to figure out quite where it's coming from. At first I thought it might be the transfer box oil seal but I can't see any oil in that area. I've cleaned it off a few times and it seems to be leaking from what I think is the speedo sender.
Seeing as I don't actually run a speedometer, I have no cable so not actually certain that it is the sender.
From looking at the image below, is this the sender and if it is the source of the leak, is this something that is a nightmare to do anything about?
Thanks!
Re: Leaky Transfer Box
Post by Jordi » Mon Aug 19, 2013 11:52 am
Yeah. Thats the speedo out. The little bolt on the bottom is to lock the cable in.
NylonAdmiral
Post by NylonAdmiral » Mon Aug 19, 2013 12:12 pm
Thanks Jordi
I'm guessing it's the speedo gear oil seal then.
Anyone got any idea where I can get one of these in the UK?
Plenty of people seem to sell them in the States. I guess if I can find the part number I can order one straight from Suzuki. Anyone know a part number?
Post by ScottieJ » Mon Aug 19, 2013 12:24 pm
Pretty sure it's just an O-ring :thumbup:
you'll need to pull the speedo drive out.
NylonAdmiral
Post by NylonAdmiral » Mon Aug 19, 2013 12:26 pm
Thanks Scottie.
From the looks of the few diagrams I've been able to find, I think I just unscrew the small bolt underneath and pull the speedo drive out right?
Seems suspiciously simple...
By the way, the photos from Wagtail look awesome!
Ladaman
Post by Ladaman » Mon Aug 19, 2013 12:29 pm
NylonAdmiral wrote:Seems suspiciously simple...
But an absolute MARE in reality.
They tend to sieze into the case. I think I cut a slot into mine to allow me to tap it around bfore pulling it out.
Good luck! ;)
Post by turbo-tom » Mon Aug 19, 2013 12:31 pm
if i remember right i bought looked at one in my local dealership and it looked like a normal O ring is it is i would say :)
NylonAdmiral
Post by NylonAdmiral » Mon Aug 19, 2013 1:08 pm
Thanks guys, and thanks Scottie especially for the picture.
Does anyone know if I can do this with the box in the truck or do I have to drop it out? I think I'm going to be lazy and try and do it in situ...
Post by ScottieJ » Mon Aug 19, 2013 1:20 pm
yeah you should be able to do it without removing the tbox :thumbup:
NylonAdmiral
Post by NylonAdmiral » Mon Aug 19, 2013 1:47 pm
Alright, fingers crossed and I'll have a crack at it one night this week then!
