How much lift do rascal rear springs give on a 410. looking at fitting them on the back and buying new front springs to match cause I have the rascal rears and trying to keep to some sort of budget. I have looked at rears up front and its a lot of fabrication to make them work and I dont like the way the helper spring sticks out. I am hoping for a bolt on/easiest way of getting a bit more lift to save the underneath of the car.
Regards Chris
rascal rears lift question.
- Edweird
Re: rascal rears lift question.
I think it's about 1.5 to 2 inches.
Yeah bout 1.5 / 2inch ruf gives good flex tho
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
cd players
99% rust free
alloys
bukets
You could always fab up a RUF kit and mix and match the spring pack removing the helper spring.
Being a 410 it's pretty easy to make an ruf set up.
Plus you should remove the helper spring when you do it anyway as it serves no purpose on the front.
Just rob Scotties bolt on front YJ design. Be easy to make that work for RUF.
Will need to be done differently to work with SJ width springs but I could maybe knock something up.
Its all circumspect now, scrap thieves robbed both my rascal springs and my spare sj rears this afternoon from my garden. Thanks for the replys chaps. going to have to start collecting springs again.
