Strange noise any ideas?
Posted: Fri Sep 20, 2013 9:48 pm
by Richie
when I turn full lock I get a loud crunch noise from the front at slow speed, only seems to make the noise once every turn. jacked it up and cant feel any play anywhere. Any ideas where to start?
Re: Strange noise any ideas?
Posted: Fri Sep 20, 2013 10:13 pm
by Darrell
Could be the cv joint.
I would jack up the front axle, put it on full lock and give the wheels a turn.
Hopefully this will let you know which side.
I assume you have fixed hubs !!
Normally when worn they will click on full lock, but sometimes they break up.
You could take the drive flanges off and spin the wheels to make sure the wheel bearings are OK
I would assume it's not the diff as it happens on full lock.
Posted: Fri Sep 20, 2013 10:25 pm
by turbo-tom
my bet is the cv joint it self is on its way out... mine is doing it all the time and pulls to the right in 4 wheel high or low!
Posted: Fri Sep 20, 2013 11:11 pm
by Richie
big job to do?
Posted: Fri Sep 20, 2013 11:16 pm
by turbo-tom
not really if your good on the spanners about 30mins if your a novice then about 45-60mins
Posted: Fri Sep 20, 2013 11:28 pm
by Darrell
I believe you can remove just the wheel spindle and withdraw the shaft from the knuckle.
I don't think this applies to all models so I would wait for somebody who knows what there talking about
Otherwise you've got to pull lots more apart
Posted: Tue Sep 24, 2013 8:20 am
If you can get an entire hub with a decent shaft already attached then that makes it easier!
The most annoying part is the damn circlips on the shaft! Even with circlip pliers they can still be fiddly little bastards sometimes!
Posted: Tue Sep 24, 2013 6:59 pm
by turbo-tom
twiss wrote:If you can get an entire hub with a decent shaft already attached then that makes it easier!
Also the little seal it self that can be a bastard aswell getting it out.
Posted: Tue Sep 24, 2013 7:22 pm
I just used pointy nose plieds to spread the clip and eased it out with a small fine screwdriver.
Posted: Wed Sep 25, 2013 7:43 am
Its getting them back on that's the pain!
Yes they very nicely threaded the end of the halfshaft to take a hub bolt, but it can still be a but of an arse!
