Quick question about front crankshaft seal..
Posted: Wed Oct 16, 2013 4:42 pm
by Jay18
Basis clay is the front crankshaft seal behind the oil pump or is it in the oil pump housing? Need to so the oil seals and could do with a bit of advice to help me a bit..
Re: Quick question about front crankshaft seal..
Posted: Wed Oct 16, 2013 5:01 pm
it's at the front of the crank, behind the lower timing belt pulley
Posted: Wed Oct 16, 2013 5:49 pm
by Jay18
Is it easy so change? How would I go about getting the old one out and new one in?
Posted: Wed Oct 16, 2013 8:19 pm
by suzukisteve
im guessing here, but mark up and remove the pulley first then you may be able to use a small pick to, well, pick tge old seal out. once out remove any dirt and crud out and put the new one in.
Posted: Wed Oct 16, 2013 8:28 pm
by turbo-tom
you have got the cambelt aswell behind if is only if its leaking id change it but if it isnt i wouldnt bother unless your doing a full engine rebuild.
Posted: Wed Oct 16, 2013 9:42 pm
by Jay18
It's definitely in need of a change cause it's pissing out oil lol, I'm hoping to get it done this weekend, I've had someone say they have a 410 engine that he's taking out and it's had the head skimmed and a new gasket so if I can get that then I'll put the oil seals on the doner engine and use that, all depends on how much he wants for it and how soon he can get it out of his sj..
