Page 1 of 2
What are the smallest tyres I can fit to a 10j wheel?
Posted: Fri Oct 18, 2013 3:18 pm
by Jay18
As in title what are the smallest width tyre I can fit to a 10j rim? And has anyone got any tyres that will fit to 10j wheels, need a set of 4 asap..
Re: What are the smallest tyres I can fit to a 10j wheel?
Posted: Fri Oct 18, 2013 4:12 pm
by dazerede
Posted: Fri Oct 18, 2013 7:27 pm
by waynesworld
It could be the easiest you are looking for is a 12.50, smaller are not easy to get hold of.
Posted: Fri Oct 18, 2013 9:52 pm
by Jay18
I had a look at that Darryl but completely baffled me lol.
Posted: Fri Oct 18, 2013 11:22 pm
by dazerede
This any good mate
http://www.brick-yard.co.uk/forum/tyre- ... 60146.html
Im sure Scottie or jordi will give u the correct answer mate
Posted: Sat Oct 19, 2013 12:15 pm
by turbo-tom
for a 10j rim I will say 12.50 and no smaller you can you put a 10.50 on a 10j but be prepared for it to come of the rim at times also they can be a bitch to mount on the rim aswell
Posted: Sat Oct 19, 2013 5:11 pm
by Jay18
thanks guys, that helps alot, now to hunt for some cheap tyres..
Posted: Sun Oct 20, 2013 7:21 pm
by Jay18
Right I have had a proper look at my wheels and it turns out they're 8j wheels, should they have 255's on them? I'm looking at fitting 235's as they're cheaper and the zuk might not slide so much with thinner tyres on..
Posted: Mon Oct 21, 2013 12:00 pm
255 or 265 or 10.50 usually go on an 8" rim.
235s are a bit narrow and would normally be on a 6.5 or 7.5 rim. Think Twiss has his fitted on standard pepper pots with no problems.
Posted: Mon Oct 21, 2013 12:04 pm
Depending on your spring condition 235/75s may foul on the bulkhead seams. Not sure aboutnthe bumper ends.
You would need a smaller profile like a 235/65/15 (if there is such a size)
