offset of fatboy rims
minibreaker
Post by minibreaker » Sun Oct 20, 2013 8:10 pm
are all fatboy rims the same offset. i am looking to be running 31s eventually but need to pick some alloys. i wanted steel modulars but i cant find any so fatboy rims look like my only option. i am needing to get 8j rims i think
waynesworld
Re: offset of fatboy rims
Post by waynesworld » Sun Oct 20, 2013 8:16 pm
I think fatboys only come in 9 or 10 j Oh and you will need 9j for 31/10.50
minibreaker
Post by minibreaker » Sun Oct 20, 2013 8:30 pm
i was gonna ask ya but i thought i would let someone else help as you have helped far to much already lol but cheers
minibreaker
Post by minibreaker » Sun Oct 20, 2013 8:31 pm
if i get 10j is that ok also
waynesworld
Post by waynesworld » Sun Oct 20, 2013 8:35 pm
10j will be ok but tight to fit, John will pull his face fitting them lol, godzuki was on 9J and tight to fit but ok, never come off even when dropped to 15 PSI.
And asking isnt really a helping out if you know what i mean.
not fatboy rims as he staes so you knock him down bit maybe, 8j better aswell
http://www.ebay.co.uk/itm/Suzuki-Vitara ... 258431aaec
Post by Jordi » Sun Oct 20, 2013 8:43 pm
Off sets are all different. Depends on the make/model of wheel.
7j or 8j are fine for 31s. When buying alloys remember that some alloys are have thicker centres than others and may require longer studs.
Rhinoman
Post by Rhinoman » Sun Oct 20, 2013 8:45 pm
The backspacing is usually 110mm, the offset then depends on the width of the rim. Some rims require sleeved nuts which can cost a fair bit, I had a set like that and ended up selling them on and getting some steels.
minibreaker
Post by minibreaker » Sun Oct 20, 2013 8:47 pm
i have seen them and really like them i just need money now lol if he still has them in a week ill be ok lol
Rhinoman
Post by Rhinoman » Sun Oct 20, 2013 8:51 pm
The steel modular do tend to be a better option as they usually have 95mm backspacing.
minibreaker
Post by minibreaker » Sun Oct 20, 2013 9:52 pm
does anyone know anywhere i can get a set of steels even wellers i like them also
