Page 1 of 2
1985 SJ Radiator
Posted: Sat Jul 04, 2009 3:34 pm
by Super413
hi,
Im looking to replace my radiator, due to general age and some damage.
Are there any variations in type of radiator that can be fitted?
Also I assume I should flush out the coolant system before fitting a new rad, what is the best practice for this??
thanks
tim :lol:
Re: 1985 SJ Radiator
Posted: Sat Jul 04, 2009 3:41 pm
by Henry
What is it going into?
the 410 and 413/sammy rads differ.
Henry
Posted: Sat Jul 04, 2009 4:32 pm
by Super413
sorry Sj 413
Posted: Sat Jul 04, 2009 4:38 pm
by Henry
Your going to need one from either the 413 or sammy. This is because they are double core and the 410s are single core and narrower.
Henry
Posted: Sun Jul 05, 2009 12:25 am
by bourneyo
yea you will need a 413/sammy rad, some burk fitted a 410 rad to my sammy and it kept overheating!
Dan 8-)
Posted: Sun Jul 05, 2009 11:26 am
by dominic
Hiya,
As above ....
Very simple job to do on the old SJ's.
Dom
8-)
Posted: Sun Jul 05, 2009 11:59 am
by Henry
Remember not to let the engine run too cool by using a rad too large. This can increase engine wear. The normal opperating temp of the engines are about 90 deg.
Posted: Sun Jul 05, 2009 5:07 pm
by Super413
Thanks people, I was planning a strainght swap, but just wondered if someone had found rads of other models of cars/trucked suited better.
How do you recommend flushing the water system?
Posted: Sun Jul 05, 2009 9:42 pm
by Henry
If i wanted to flush it i would shove a hose pipe down the top hose and turn it on. However i have removed my thermostat. What you need to do is rake the round cap off (2x12mm bolts) off the top hose on the inlet manifold, pop the stat out, and shove the hose in. However you shouldn't need to flush it in all honesty.
Posted: Sun Jul 05, 2009 10:50 pm
by Super413
Thanks for the tips, will just stick a hose in and flush it thorough!
These are all jobs im planning for when im back in the UK in august!
