adapter plate
Emyr
adapter plate
Post by Emyr » Sun Oct 27, 2013 7:52 pm
Hi, im fitting a 1.9D pug/ldv engine in my old samurai. Obviously engine doesn't fit onto Suzuki gearbox. Anybody know where i can get a convertor/adapter plate to make it fit?
cheers. Emyr.
Boyes
Re: adapter plate
Post by Boyes » Sun Oct 27, 2013 7:55 pm
Most use the LDV 200 box.
Emyr
Re: adapter plate
Post by Emyr » Sun Oct 27, 2013 8:01 pm
And fit onto the transfer box?
gp7186
Re: adapter plate
Post by gp7186 » Sun Oct 27, 2013 8:42 pm
You will need a custom made short propshaft to couple the gearbox to the transfer box when I did mine i made it 130mm long I think which is very short
Boyes
Re: adapter plate
Post by Boyes » Sun Oct 27, 2013 8:55 pm
Yes, mine is silly short literally two uj's with a weld between. I've known someone run just one UJ
Emyr
Re: adapter plate
Post by Emyr » Sun Oct 27, 2013 11:11 pm
Thanks
waynesworld
Re: adapter plate
Post by waynesworld » Mon Oct 28, 2013 8:40 am
Hi kida, when i did mine i used the LDV pilot propshaf to join to the SJ transfer box, if you get the UJ from the T box and use just the UJ by cutting off the prop the cut end of Pilot prop will fit over it nicly to make a prop your own length.
To balance it myself i fitted the T box where i wanted it ( after i did this i dont think i needed to actualy remount to T box ) also the G box, then i turned the T box and when the prop wasnt...say wobbly, i tacked and welded it up, i done thousands of miles like this and towing a caravan without any problems.
Good luck kida
wolly :D
