Front Axle Seals
Scouse Lee
Front Axle Seals
Post by Scouse Lee » Mon Oct 28, 2013 4:08 pm
Hi guys, I jacked the front of my SJ413 up and had a good tug on the wheels, there is far too much play in them by the look of it, top/bottom & side to side.......I also had a load of (diff?) oil p*ss out, so what do I need to do, ie which seals do I need, swivel? diff?.......and what about bearings, kingpin? wheel?.......I have seen the diagrams on here but don't know what I'm best getting.......can you get a full seal kit at all, (I got one for my Hilux once which was good)....and where's the best place for stuff like this as I'm having trouble finding anything atm.
Lee
Re: Front Axle Seals
Post by dan_2k_uk » Mon Oct 28, 2013 4:18 pm
Carrying on from our chat on Facebook.
You might be able to remove a few shims from the kingpins to tighten it up a bit but you would need to pull the hub to check the condition of the existing bearings.
You are going to need to remove the whole hub anyway to replace the half shaft seal in the end of the axle as its sounds like its leaking diff oil anyway.
To be honest i woud just do the lot while its all apart.
Post by turbo-tom » Mon Oct 28, 2013 4:26 pm
You might find this link helpful:
http://forum.difflock.com/viewtopic.php?p=707407#707407
i did mine based on this guide and the lads on here first time and once you getting going it isnt a big brainer its simple only nuts n bolts and cir clips!
Scouse Lee
Post by Scouse Lee » Mon Oct 28, 2013 4:48 pm
dan_2k_uk wrote:Carrying on from our chat on Facebook.
Nice 1 Dan......I'm on that many FB sites I get confused as to who I'm talking to and didn't realise that was you haha.......I've got new,(well 2nd hand), springs to put on the front so I may as well remove the axle and sort it out while I'm there, so what do I need then:-
Wheel Bearings
Kingpin Bearings?
Half Shaft seals
Swivel Bearings?
Scouse Lee
Post by Scouse Lee » Mon Oct 28, 2013 4:49 pm
turbo-tom wrote:You might find this link helpful:
ah thanks Tom that looks just the job :thumbup:
Post by twiss » Mon Oct 28, 2013 4:51 pm
The method in the last post is how I do it... just take the covers off the back, remove caliper and steering link then yank the entire hub and shaft out
Scouse Lee
Post by Scouse Lee » Mon Oct 28, 2013 5:26 pm
Scouse Lee
Post by Scouse Lee » Mon Oct 28, 2013 5:30 pm
actually this one is cheaper although it looks the same and is from the same dealer, (says may be subject to customs processing and additional charges though?)
http://www.ebay.co.uk/itm/Swivel-Hub-Wh ... 5d452df695
Post by twiss » Mon Oct 28, 2013 5:31 pm
Yeah I would say for £100 thats a bargain... will take AGES to arrive though probably :(
You will probably have to pay 20% on top for import duty
Post by turbo-tom » Mon Oct 28, 2013 5:38 pm
That is the kit i used for mine with everything pretty much was about £17.20 or something i got stung on.
