5/1 diffs miff or legend
Are these diffs any good where do you get them from thanx! Any info is much appreciated.
Re: 5/1 diffs miff or legend
If its a manual you should already have them in your vit.
Here's the info page
http://forum.suzukiclubuk.co.uk/vi ... =12&t=2801
Do 5/1 diffs lower the ratios in Sami axle. And where are they found thanx.
Have a read here http://www.suzukiclubuk.co.uk/diy/16-tr ... conversion
Personally I wouldn't fit 5.12:1 vit ring and pinions unless you run 33+" tyres 4.6 are good for 31s.
Or just regear the transferbox.
Cheers I'm told 5/12.1 come from pre 98 vitaras
They come in pretty much every manual 1.6l vitara and some grand vitara's. Only the front ring and pinion fits samurai diffs though.
I was sure I had already replied to this the other day. Merged the two topics.
5.125 ratio diffs are found in pre 97 1.6 manual vits in 97 they changed to 4.875 ratio
