Starting issues
chuff
Starting issues
Post by chuff » Sat Nov 02, 2013 7:11 pm
Good evening Guru's
My issue is as follows.
Car wont fire, cranks over fine, no sign of life from rev counter, but wont fire. BUT its very intermittent, can be fine over and over then nowt.
We have changed the ignition switch ( told serviceable ) - still the same.
We have cured this by fitting a jumper wire from battery to coil with a switch and it was fine for a while.
now it wont start some times even with a jumper wire
So, i think we have 2 issues - ignition switch and a wiring issue.
any thoughts welcomed.
Also, as this is now only off road use, anyone done away with their ignition and just wired up a cut off stich and start button - if so, a noddy guide ?
Thanks in advance
Bought it, moved it, drove it, then my mate rolled it.. . . . .
Re: Starting issues
Post by turbo-tom » Sat Nov 02, 2013 7:15 pm
12v wire from the s post terminal on the back of the starter thin wire and dab it on the positive side of the battery try that.
Re: Starting issues
Post by ROBBIE » Sun Nov 03, 2013 8:38 am
Coil?
suzukisteve
Re: Starting issues
Post by suzukisteve » Sun Nov 03, 2013 11:40 am
ye id agree with robbie, have you replaced the coil yet?
pickle power!
Re: Starting issues
Post by twiss » Sun Nov 03, 2013 11:55 am
I would also try replacing the coil if you can get one cheap or have a spare...
But it sounds like you do indeed have a wiring problem as well, possibly which has finished off the coil.
One of my mates had a similar problem and needed a coil wire but I can't remember what caused it.
Although if you do put a different coil on you may still need the coil wire
Is your fusible link OK?
Try tracing the coloured wires coming from the coil.
chuff
Re: Starting issues
Post by chuff » Sun Nov 03, 2013 1:29 pm
coil switched out, still the same :S
fuselink - doesnt appear to have one :!:
now the starters given up playing. :pissed:
next up a re-wire me thinks :bawling:
