Samurai diffs into 413 axles? 413 axle on sj410?
Jay18
Post by Jay18 » Mon Nov 04, 2013 7:08 pm
I'm just doing a little more research into fitting a 1.6 to my 410, not 100% sure if I should yet but well see..
Basically do samurai diffs go straight into 413 standard width axles? And to 413 axles bolt straight in place of 410 axles? (Think someone told me they do on here)
And would this setup be a good setup on my 410 for a 1.6? Anything else I can do to the ratios to make her cruise at motorway speeds (60mph) a bit easier, I plan to fit 29" tires..
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Re: Samurai diffs into 413 axles? 413 axle on sj410?
Post by Jordi » Mon Nov 04, 2013 7:38 pm
Just fit 413 axles. On 29" tyres the difference in the diff ratio will hardly be noticed.
Sure 410 / 413 spring spacings are the same but 413 axles are thicker and require bigger u bolts.
Samurai diffs will bolt straight into 413 axle cases if you wanted.
A 1.6 onto a 1.3 gearbox, 410 t/box and 413 axles should cruise pretty well.
At a comparisson mine is on samurai axles with a rock lobster and cruises at 65 ok.
Jay18
Post by Jay18 » Tue Nov 05, 2013 5:33 am
Cheers jordi! I had a feeling id need to get new u bolts, so 413 diffs the same ratio as samurai diffs?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by dan_2k_uk » Tue Nov 05, 2013 6:35 am
Near as makes no difference the same. Just make sure both front and rear are the same as you will get bad transmission wind up if you fit one of each.
Jay18
Post by Jay18 » Tue Nov 05, 2013 8:45 am
Cheers Dan will make sure to fit two 413 axles if I go for the conversion..
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by Jordi » Tue Nov 05, 2013 10:03 am
413 diffs are 3.9. Sami diffs are 3.7.
Jay18
Post by Jay18 » Tue Nov 05, 2013 11:39 am
Ahh right, and does anyone know is the 410 prop shafts will bolt to the 413 diffs?
Samurai gearboxes are different ratios to normal 413 gearboxes aswel aren't they? So would a Sammy gearbox be better?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by andyrew » Tue Nov 05, 2013 12:57 pm
Samurai box has lower 5th gear if im correct
Probably a lot easier getting a samurai box
Post by Jordi » Tue Nov 05, 2013 1:58 pm
Again, difference in gearbox ratio won't make a lot of difference.
As for the props, depends what size flanges your new axles have. I think it's just Samurais that have the big and little flanges. Think 410/413 are the same. Sure someone more educated will confirm this.
Jay18
Post by Jay18 » Tue Nov 05, 2013 6:54 pm
Okay thanks again jordi, will have to see what I feel like doing when I'm 21, either buy a vit or mod the sj..
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
