Page 1 of 3
Engines
Posted: Mon Nov 04, 2013 8:21 pm
by b3n16
Just because I'm curious and thinking
Does anyone know what sort of straight forwardish engine swaps there are for the Vitara?. Any that use a different gearbox to the standard Vitara?. Any help or ideas would be cool.
Re: Engines
Posted: Mon Nov 04, 2013 8:29 pm
J20a out of a GV is probably one of the easiest. Will bolt up to the 1.6 gearbox but needs a modded flywheel.
Re: Engines
Posted: Mon Nov 04, 2013 8:31 pm
by b3n16
Being what mate?. A 2.0l I assume?. Do you use the gear box with this?.
Re: Engines
by b3n16
Sorry I meant can you use the gearbox
Re: Engines
Posted: Mon Nov 04, 2013 8:47 pm
Yeah a 2.0 16v with 126bhp.
I edited my last post, it needs the flywheel modifying, the crank bolt patterns are different and a section needs to be machined flat. Apart from that it bolts straight up to the 1.6 gearbox, will need to make new engine mounts and there's quite a bit of wiring involved as well, however the 2.0l has a separate engine harness so that makes life slightly easier.
Re: Engines
Posted: Mon Nov 04, 2013 8:49 pm
by b3n16
Would it be worth it or is the change not that noticeable?.
Re: Engines
Posted: Mon Nov 04, 2013 8:55 pm
Here's a pic of what needs to be done to the flywheel inner bolt holes are the 1.6 outer 2.0
- image.jpg (101.17 KiB) Viewed 7360 times
It's a pretty much unheard of conversion over here to be honest but it's almost 1/3 more power and torque. I'm planning on replacing my 1.6 8v in the Sj with one, have it in the workshop already
What 1.6 is in yours at the moment?
Re: Engines
Posted: Mon Nov 04, 2013 9:27 pm
by b3n16
I really don't know if I'm honest. I think it's the 1.6 8v
Re: Engines
Posted: Mon Nov 04, 2013 10:18 pm
by donkeychomp
Put up a piccie...then we'll know!
Re: Engines
Posted: Tue Nov 05, 2013 4:01 pm
1.6 16v is a good engine! easy as well in a vit i would guess!
Not really worth the effort though unless you get the engine for peanuts!
