front wheel bearing quesition
dazerede
Post by dazerede » Tue Nov 05, 2013 5:58 pm
So I have took the front wheel bearing out and it looked a bit rusty but ok so when I wiggle the shaft there is a bit of play between the shaft and something but is that kingpins gone I have took the disc off and that thing that holds the disc on
4” calmini lift kit :)
dazerede
Re: front wheel bearing quesition
Post by dazerede » Tue Nov 05, 2013 5:59 pm
The shaft wiggled in between this
Post by ROBBIE » Tue Nov 05, 2013 6:05 pm
There is some play in the shaft. If kingpins there will be ply in the hub you wont see it in the shaft and looks like you've had some water in there
dazerede
Post by dazerede » Tue Nov 05, 2013 6:08 pm
Ok can I check if kingpins are in good condition at this stage
Sorry for me being dum but I'm only 18 :oops:
Post by ROBBIE » Tue Nov 05, 2013 6:14 pm
Would have been better if it was all on, but try moving it up and down and see if hub moves. Either try the part where the bearings bolt up or grab the back plate, hands at 12 and 6, and push pull, Look round the back and see if there is any movement of the hub
dazerede
Post by dazerede » Tue Nov 05, 2013 6:22 pm
Ok I will have a look the seals are all good and I have already ordered the wheel bearings
So let's hope its just the wheel bearings fingers crossed
dazerede
Post by dazerede » Tue Nov 05, 2013 6:29 pm
I have just checked and I can't feel any movement at all so all is good chears
Post by ScottieJ » Tue Nov 05, 2013 11:12 pm
If water has got in there it will more than likely be in the swivel housing as well so I would personally strip that down and give the kingpin and CV joint some fresh grease before you put it all back together. Don't forget to use silicone when fitting the fwh/drive flanges.
The shaft is supposed to float in the stub axle like that. it's the fwh/drive flange that holds it central.
Post by ROBBIE » Wed Nov 06, 2013 9:23 am
Good point and I would check your diff oil as well
dazerede
Post by dazerede » Wed Nov 06, 2013 9:39 am
Ok chears guys
