will they fit ???
minibreaker
will they fit ???
Post by minibreaker » Wed Nov 06, 2013 9:04 pm
i have a virtual lift on my samurai but nothing else will 31s fit or do i need a 2 inch body lift thanks in advance
suzukisteve
Re: will they fit ???
Post by suzukisteve » Wed Nov 06, 2013 9:09 pm
depends on the size of the vl to be honest dude, and if the front bumper has been trimmed or removed etc
pickle power!
Post by twiss » Wed Nov 06, 2013 9:14 pm
i reckon i will get 31s on mine with a 3" lift... so probably will be workable!
Post by Jordi » Wed Nov 06, 2013 9:22 pm
They will fit with just a virtual lift as long as a few inches have been taken out of the bulkhead too.
Post by turbo-tom » Wed Nov 06, 2013 9:26 pm
twiss wrote:i reckon i will get 31s on mine with a 3" lift... so probably will be workable!
we can try it if you want one day bud ;)
Post by Jordi » Wed Nov 06, 2013 9:33 pm
Need to cut the bulkhead or run decent size extended bump stops. Anything but a straight flat road and they foul big time. 31s fill the arches front to back top to bottom.
Post by ScottieJ » Wed Nov 06, 2013 9:46 pm
I used to run 31x11.50 tyres on my Sj with just 2" lift springs and 2" dropped bumpstops, all I had to do was cut the front crossmember ends off and fold the bulkhead seam over, the narrower 410 axles helped a bit with clearance though.
how much have you virtual lifted it by?
Post by donkeychomp » Wed Nov 06, 2013 10:07 pm
You'll need a 410 tbox. The lack of speed is amazing and it'll kill prop UJ's too.
Post by Jordi » Wed Nov 06, 2013 10:12 pm
donkeychomp wrote:You'll need a 410 tbox. The lack of speed is amazing and it'll kill prop UJ's too.
I found gearing to be a mile out but never broke anything or found it too slow. I would recommend a 410 t/box if you can get one?
Post by ScottieJ » Wed Nov 06, 2013 10:14 pm
Bad propshaft angles and axle wrap are what kill UJs.
I've never had an issue with UJs running big tyres. Don't buy cheap Ujs though, they suck :lol:
410 tbox will help with the gearing, better to run a rocklobster though ;)
