Does anyone know where I can one of these ??
Tregembio
Post by Tregembio » Tue Nov 19, 2013 10:35 am
Had to do the clutch on my samurai and notice as I took the clutch plate off this bearing was buggered . It has got a vitara 1.6 eight valve in it the engine code is g16a . Any help would be much appreciate . Cheers
Liam
Re: Does anyone know where I can one of these ??
Post by ScottieJ » Tue Nov 19, 2013 12:33 pm
From what I can find it should be a double sealed 10x30x9mm bearing. same as on the sj410.
the code is 6200 2rsr
Rhinoman
Post by Rhinoman » Tue Nov 19, 2013 1:02 pm
ScottieJ wrote:From what I can find it should be a double sealed 10x30x9mm bearing. same as on the sj410.
yes, I was also wondering why that bearing has no seal.
Post by ScottieJ » Tue Nov 19, 2013 1:04 pm
:lol: could be why it's no longer any good :lol:
Tregembio
Post by Tregembio » Tue Nov 19, 2013 3:39 pm
Nice one ! Thanks Scott . Other thing I was meant to ask , was can you run without it ?
Post by ScottieJ » Tue Nov 19, 2013 4:08 pm
Tregembio wrote:Nice one ! Thanks Scott . Other thing I was meant to ask , was can you run without it ?
I would not run it without one, it supports the gearbox input shaft, plus for a £5 component it's not really worth the risk.
ferris
Post by ferris » Tue Nov 19, 2013 4:26 pm
I had the same problem with mine when i changed the gearbox. Just took the remains of the bearing to my local bearing supplyer and they were able to match it up with one off the shelf.
Post by twiss » Tue Nov 19, 2013 4:29 pm
The question is... where did the other ball bearings get to???
Post by Darrell » Tue Nov 19, 2013 7:38 pm
Nowhere, that's all you get ;)
But the cage has gone walkies..
Tregembio
Post by Tregembio » Wed Nov 20, 2013 6:15 am
Yeah didn't find the cage , seal or the other ball bearings :/ never mind . Bearing should be here today and all being well she will be back on the road :) thanks again .
Liam
