235/75/15 Tyres on a sj 413 with no Lift
Hello all,
As some of you might have seen i have recently purchased an SJ and was looking at going down the 2" lift route, with this being expensive i thought i would start with some decent tyres for a bit of green laning and maybe some pay and play days.
So i have found these on ebay
http://www.ebay.co.uk/itm/4x-235-75-15- ... 27d954ee4b
My question is what exactly do i have to do to get these to fit.
As far as i can work out it is as follows,
cut the cross member back behind the bumper?
Cut the bumper down or run a different one?
Maybe fold back the bulkhead seams?
Would it make any difference adding wheel spacers as well? (more clearance on the inside of the arch how would this affect the out side arch?
Re: 235/75/15 Tyres on a sj 413 with no Lift
Dude...what wheels you gunna run? i have 235/75 x 15 on my 88 SJ and all i needed to do was grind a bit of the bumper off and the bumper support. The tyres rub a bit on full lock so need to grind a bit more off the support.
My wheels are 7 x 15 Daihatsu alloys
- IMG_2080.JPG (3.6 MiB) Viewed 7575 times
- IMG_2438.JPG (3.2 MiB) Viewed 7570 times
I have a set of steel wheels at the moment i think there 6" maybe 7".
What do they rub on mate the bumper?
- dazerede
I have 235 75 15 on.my standard hight sj and it is fine
4” calmini lift kit
4” calmini lift kit
The vertical edge is un cut dude...the top and bottom section have been trimmed a little
some with my bumper cut as it is i shouldn't have any problems?
- IMG_4103.JPG (2.33 MiB) Viewed 7551 times
- dazerede
Ye 235/75/15 would fit ideal
Best option is to find someone with 235/75/15 tyres and fit them to urs and see if they catch and look alright I reckon u could fit 30" tyres in there as 235/75/15 are 29"
4” calmini lift kit
4” calmini lift kit
Daz how is yours with the wheel spacers?
I've got 31's on mine and when it was standard height they fit with clearance, I just had to chop the bumper support off and flatten the seam in the back of the front arch and that was enough clearence, I do have a virtual lift though so that could be completely different, you should be able to get 235 75's in with no problem, and if they were to catch the chassis or spring then it's fairly easy to get a set of spacers and some rubber to extend your arches...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Looks to me like you've already got a virtual lift..
If I was you id go for some 31 x 10.50 R15's, with a small amount of modification to the front bumper supports I recon you'll be good to go
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
