Page 1 of 2
Rear Bumper Idea's
Posted: Sun Dec 22, 2013 9:45 am
by Famerbennie
Hi All, Thinking Of Making A New H/D Bumper For The SJ And Wondered What Others Had Done
Re: Rear Bumper Idea's
Posted: Sun Dec 22, 2013 7:15 pm
by dazerede
Are you planning on putting lights in.the bumper if not just use some 50x100 box section
This is my rear bumper I am planning on making a rollcage for my zook one day so I will.mount it to this bumper
Posted: Sun Dec 22, 2013 9:40 pm
by dan_2k_uk
Have a flick through my build. I made one from some steel tube with LED boat trailer lights in it.
Posted: Sun Dec 22, 2013 9:46 pm
by i_am_me
its not a sj but the general design could be used.
made from 2" box section with landrover defender tail lights set into it.
Posted: Sun Dec 22, 2013 10:22 pm
by mike harris
Mines just box section, but it's sleeved inside so won't crush
Posted: Fri Dec 27, 2013 11:06 am
by Famerbennie
Thanks Guys
dazerede How Did You Recess The Lights In The Bumper?
dan_2k_uk Did You Have To Use A LED Flasher Relay When You Used LED Lights?
Posted: Fri Dec 27, 2013 9:38 pm
by dazerede
I didn't make the bumper but all it is you cut the hole out only threw one side and put a bit of tube the right width and weld it in there if you know what I mean
Posted: Fri Dec 27, 2013 9:40 pm
by dazerede
But if you do it that way make sure you have room for a number plate and 2 number plate light as I had to put the number plate down a but with the light above it
Posted: Fri Dec 27, 2013 10:02 pm
by ROBBIE
Dazerades bumper looks like a no fear zuk one off ebay. Same as the one I have, but the one I have has sides on to look like a Sammy one.
Posted: Fri Dec 27, 2013 10:25 pm
by dazerede
Ye its does look like a no fear zuk one eBay but it isn't a chap on.here made it called 4some I believe
