1.3 1.6 inlet manifold
- timwilks13
- SCUK Website Padawan
I have put my 1.3 manifold onto the 1.6 block as it was modded for the su, but noticed the inlet holes are slightly bigger on the 1.6 than the 1.3, will this cause any issues?
Re: 1.3 1.6 inlet manifold
Ever so slight power loss but as its a off roaster and not a race car it prob not even noticeable I did same on mine
if in doubt, FLAT OUT!
Yeah it won't make much of a noticeable difference to be honest
It will probably only effect the top end if anything.
- timwilks13
Of you lot that have done this what fuel pump did you use? Just looking on eBay and there are hundreds to choose from!!
Facet low pressure pump. 1-4psi I think.
Mines like this... not had any problems with it... ideal psi is about 3.5 iirc
http://www.ebay.co.uk/itm/Facet-12v-Low ... 5d418a293f
Click Here for Ebay Listing
