Clutch adjustment
Posted: Sat Jan 11, 2014 6:51 pm
by george123
Hiya guys quick question how would you adjust the clutch on a sj410? Got the cable of by undoing this one nut which was on a long thread to adjust it with a new clutch do I just wind up more?
Re: Clutch adjustment
Posted: Sat Jan 11, 2014 6:58 pm
by Ladaman
Yep, that's it.
Leave about 3mm of slack in it though, don't nip it up.
Posted: Sat Jan 11, 2014 7:01 pm
by george123
Do you mean slack of the cable it slack of where the cables sits on
Posted: Sat Jan 11, 2014 7:54 pm
by Ladaman
According to the manual it says 2-3mm of free movement on the pedal, where you press with your foot. But to save getting up and down, I tend to just make sure there is a little clearance between the operating arm and the round bit that fits into it. It's just to make sure the release bearing isn't riding on the cover plate.
Posted: Sat Jan 11, 2014 8:34 pm
by george123
Ahh okay thanks because the nut was wound right to the very end with a new clutch in it could this be why it's not going into gear when the truck is turned on
Posted: Sat Jan 11, 2014 8:42 pm
by Darrell
Ladaman wrote:According to the manual it says 2-3 CM of free movement on the pedal, where you press with your foot. But to save getting up and down, I tend to just make sure there is a little clearance between the operating arm and the round bit that fits into it. It's just to make sure the release bearing isn't riding on the cover plate.
